No. That’s the note from step 3b that you don’t want to edit.
You’ll need to revert that change – probably just easiest to restore the Custom Tile definition using the Update from Source option as noted below.
Once you have the tile definition back to the originally settings, you want to continue on to step 4 where you add the tile to your dashboard and then edit the settings for the tile on the dashboard.
Also note that step 4 calls for the latitude, longitude coordinates for your location. The original post has notes on how to find this.
