@josh is this possible with Ring Doorbells?
Iâve seen people doing this on Amazon Fire Tablets and Android Tablets.
From what I understand, the basic concept is to use an automation app like AutomateIt (Fire OS) or Tasker (Android) to detect whenever a specific notification is received on the Ring App⌠then when that notification is received, automate clicking on the notification or opening the app.
Note: If I remember correctly, some people mentioned that the Ring app previously would launch the video stream right away when you opened the app (if a doorbell event was active), but Ring changed that in recent versions and it just loads the landing screen.
Others have mentioned that if you automate the clicking of the notification that is received, it will open directly to the video feed.
If you get it working let us know what approach you took!
â
On a related note - since people may find this post while searching or may just want to manually be able to open the Ring app, the following post includes details on the âURL Intentâ for the Ring App and the new Rapid Ring app: Ring Doorbell on dashboard - #2 by josh
â
Note that the way things are working in @Kentâs setup is he has a Sage Doorbell sensor to detect whenever the doorbell is rung.
From what I understand, these sensors are discontinued, but thereâs a ton of them that hit ebay recently for dirt cheap. As Kent noted, the Nexia DB100Z seems to be a reasonable alternative as well.
In Kentâs case, his porch camera has a stream thatâs compatible with being displayed in a SharpTools dashboard directly, so heâs setup a rule that whenever the doorbell is rung, it uses the Fully Kiosk Browser Controller integration to change to a dashboard which is showing his camera full screen.
Thanks for the detailed response. I have a Fire 8 tablet, so Iâll look into it.
How does one use the fully kiosk browser controller? I have the Sage doorbell sensor and installed it, works fine with Smarthings.
But not sure how to trigger it so that when the sensor goes off, to open up one of my media tiles that I have setup to stream my camera?
You would install the Fully Kiosk Browser Controller DTH and then setup a rule to use the loadUrl() command to load your desired URL when the doorbell sensor is activated.
Edit: The above linked SmartThings DTH is no longer available, but I put together a Fully Kiosk driver as an extra benefit for SharpTools premium users in my personal time. PM me if interested.
The Fully Kiosk Browser Controller device can open URLs, so you would want to have a dedicated dashboard with your stream as a large tile on it or even just open the stream URL directly.
As far as Iâm aware, the Fully Kiosk DTH canât âclickâ a tile, so it canât open an existing tile full screen⌠but you can use the trick of opening a different URL which has the media displayed in a large format.
Cool, and the âloadURL()â rule is inputted where/how?
You could do it in the SharpTools.io Rule Engine or in the rule editor of your choice.
Sorry, still learning at this. Tried that, but keep getting stumped. So I do the following:
- Create a Rule
- Select a trigger as my Sage Doorbell
- Not sure whether to select âButtonâ, âPresenceâ, or âSupported Valuesâ (Iâm assuming itâs not this one as there doesnât seem to be any values)
- If âButtonâ, then there is a bunch of values in there like âdownâ, âPushedâ, double. I tried âdownâ.
- I then selected a Flow, being the Fully DTH and executed a load URL command with the video URL.
Unfortunately, nothing happened.
@S_D, try using âButtonâ and âpushedâ as the trigger. See below for example where my trigger is a Ring, but it should be similar.
A couple of tips when troubleshooting rules. ![]()
- To verify if the trigger is configured properly, add an email notification in the flow, so you know if the rule was triggered based on if you received the email or not.
- To test the rule activities, add the rule to a dashboard using ârule tileâ so you can tap the rule tile to âmanuallyâ trigger it and verify if it executes the desired activities.
Thanks, that was helpful. So Iâm getting an email, but nothing is happening in Fully? Same thing when I press the Sage tile, nothing comes up.
Maybe a setting needs to be changed in Fully itself?
Thatâs a good progress knowing you received the email notification. ![]()
It does sound like the Fully device might not be configured properly. Please follow the âSettingsâ section in the post below to verify your settings.
Once done, you can open your SmartThings classic app and tap Screen On and Screen Off in the Fully device and it should be able to control your Fully Browser on your tablet and turn the tablet screen on/off.
Okay, had to change the password and resave.
So it works now, however when the URL is brought up, the screen size is enormous, larger than the 8" screen so I only see a small portion of the image. Is there a way to reduce the size of the image that comes up via the URL?
Also, the URL just stays up forever, and to remove it you have to left swipe and select âGoto Start URLâ, doesnât appear to be an âxâ on the image to go back to the start URL without having to swipe first.
Thinking about it some more, is this doable instead?
- Use Sage doorbell sensor to trigger a rule
- Have the rule set so that when the sensor is triggered, it loads the âtincam monitor freeâ application (which I can set up to only show the front door camera)
I can then use Automateit to flip back to Fully say after a set time.
The above may be useful since tinycam monitor free offers the ability to use the mic an speaker from the camera.
I believe you should be able to accomplish that with the Fully Kiosk Controller launchAppPackage() command, similar to what was done in this thread:
I believe the app package for TinyCam Pro is: com.alexvas.dvr.pro
And the app package for TinyCam Free would be: com.alexvas.dvr
Thanks! So Iâm changing the Sage rule to LaunchAppPackage instead of launchURL, but there is no ability to insert the app package name anywhere?
Try opening up the Fully Kiosk Browser Controller device that was created in SmartThings, edit the device preferences, and set the âApplication to Launchâ to com.alexvas.dvr
Then you should be able to use the launchAppPackage() command without specifying an app name as a parameter.
Perfect, that works! Curious, there is no way to set a String in the rule engine to do this? Would be awesome if there was, so that one could use it with various apps.
It looks like the Device Handler doesnât define that it accepts a parameter in its metadata even though the command actually does.
The device handler could be updated so that it indicates that it accepts a parameter. To do this on your own, you could edit line 52 and add a single âStringâ parameter.
Changing it from:
command "launchAppPackage"
To:
command "launchAppPackage", ["String"]
After making the change and then saving/publishing it, you would need to reauthorize the device in SharpTools to pull in the latest changes.
â
Weâve also noted a potential enhancement - updating the SharpTools Rule Engine to let the âAdvancedâ toggle forcefully add parameters to devices even if the device doesnât report that it accepts parameters.
@James 2 questions on this:
1 - How do buttons work in Sharptools? My Ring Doorbell doesnât have the âbuttonâ attribute it has a âpushedâ attribute that tells which button number was pushed. This is in Hubitat with the unofficial Ring support. I created a virtual button in Hubitat and it has the same, although you can specify in the settings how many buttons there are so I suppose I could have a rule âpushâ button 1 and then âpushâ button 2 so I could see it change in Sharptools, but is there a way to use Hubitat buttons in rules?
2 - On the dashboard you take FKB to on the push, do you have it loading the Ring video doorbell video / image? If so, where do you get the URL for that?
Thanks!
You can push your Ringâs physical button and check Hubitat deviceâ event history to see what value it reported in the pushed attribute, and use pushed as the attribute in the rule trigger with the value you found to trigger the rule when some pushes the Ringâs button.
Unfortunately, Ring doesnât support RTSP and there is no official way to pull the live stream, so you wonât be able to display the video/image on the dashboard. But the you can have the Fully browser to open the Ring app automatically when someone pushes the button by using the following intent URL. The down side is Ring app doesnât support redirecting to the specific cameraâs view page with the intent URL, so you will have to tap the specific camera to view the video.
Ring intent:#Intent;launchFlags=0x10000000;component=com.ringapp/com.ring.launch.LaunchActivity;end
Rapid Ring
intent:#Intent;launchFlags=0x10000000;component=com.ring.answer/com.ring.answer.presentation.splash.SplashActivity;end
Or you can try another approach described by @Automated_House to use Alexa Routine to show the ring camera on the Fire tablet. You can create a virtual-contact-switch device using the HE community developed device handler, and turn this virtual device to on (open) in the rule, and have the Alexa routine to be triggered by this virtual device. (Alexa routine cannot be triggered by âswitchâ, but can be triggered by the contact open/close.)
I have other RTSP enabled cameras feeding the live streams to the dashboards via Blue Iris, so my rule was asking FKB to navigate to my âsecurityâ dashboard when someone pushes the Ring button.
