This is the dashboard for Princess, my beautiful white Tesla Model Y. This dashboard is linked to my Home dashboard.
It makes use of the custom Tesla integration available for Home Assistant.
The tiles are view only. Originally I was going to allow control of some of the functions, but when I went into the garage and found the trunk opened by an inadvertant touch I decide that all I really wanted was status. The phone app controls things nicely when needed.
Another consideration is the terribly long polling interval. The recommendation is an eleven minute interval to avoid waking the car and unnessarily draining the battery. Press a tile and wait eleven minutes to confirm that it worked!
Love it. I know over there, you call the Boot a Trunk, but I’ve never heard the Bonnet (Hood) called a Frunk…I guess in the UK Tesla will call it a Froot…
I have been a long time user of ST back when I was on Android. Purchased AT long ago but never took the time to build a Dashboard. I went the Dakboard route. While that was fine (it’s only a display) - the price point increases for Dakboard and the lack of functionality had me looking to move to building out a touchscreen.
My challenge is, we moved from Android to Apple a while back. It wasn’t until I came across this mounting solution that I really decided to dive in:
With that said, using the Apple App tKiosk, I was able to integrate the Kiosk as well as a screensaver function (which I still use Dakboard for the screen saver - free mode)
My cameras are UniFi Protect hosted, you can achieve a feed by simply calling the snapshot.jpg URL by camera IP and refreshing - which is fine for me - otherwise I would need to deploy a RSTP to MPEG solution, which I’m not ready to do - yet.
I actually built out this exact dashboard in both ST and AT.
AT allows the pulling in of “scenes” or “routines” - but ST can replicate with Rules.
What really brought me over fully to ST?
The iframe HTML code (for weather alerts) - custom tiles.
I enjoy the themed calendar (even though you can do the same using Google Calendar Agenda View).
Another huge win is the complete flexibility on icon states / theming. Although, it’s usually enough, AT only has four potential icon “intentions”.
Also, the grid creation UI of ST is outstanding - most importantly, being able to span rows with a tile, without moving all rows below the single tile you are spanning.
Two items I do miss from AT - the “paneling” which allows for labeling of blocks of similar icons and the integration of sensor battery level integration without needing to use “hero” tiles.
Only thing I am missing at this point is integrating my “whole house audio” system which is running on Home Theaters Direct (HTD) equipment using HTD Gateway.
If anyone knows how to work with the HTD Gateway API, I’d love to hear about it.
I’d also like to hear from anyone in Smarthings beta and the “edge” / “matter” migration. Does this potential impact our dashboards? I understand all DTH apps will no longer work (unless recoded)?
I’m considering a move to Hubitat - but with 94 devices, not looking forward to the readding of every device to a new hub.
We also have a private beta that just went live for a next generation SmartThings integration which exposes the Scenes functionality as well. Feel free to send a note to support@sharptools.io for more details.
There’s a feature request for Visual Grouping of Tiles that you may be interested in casting a vote on.
Is this for the various contact, motion, and water sensors in your screenshots above? I don’t believe there’s a feature request for this yet, but feel free to create one.
I’m going to break this part of the post out to its own thread as it’s likely to generate some discussion.
About the paneling…
For example, above I have a dashboard - bedrooms.
I have each room represented by a row of tiles.
This works, but if you wanted to drop the tile title or shorten it, you would be confused what’s what.
Every room has a fan, light, etc… So every tile has to say - for example - Master Light, Kids Light, Guest Light, etc… Rather than grouping them in some sort of way, perhaps a background color? That way you could leave all the tiles as “Light” but know which room they belong to by the grouping…
Hi @Cory_Booth. Great layout! I also use Unifi Protect cameras but not hosted (using my UDM SE controller). Been struggling on trying to use the camera’s RSTP feeds but as everyone knows, browsers do not allow RSTP feeds. I know that there is a way to capture/use snapshots for each camera as you described, but have not been able to figure it out. Do you mind sharing how you did yours? I have two G4 Pro cameras and one G4 Bullet. My cameras are on a separate VLAN. Thanks!
Thanks Cory… For some reason I cannot access the camera login page (http://10.0.x.x/login) as it gives me the infamous Your Internet access is blocked page error (I am assuming the UDM firewall is blocking it somehow). Maybe it’s because it is on a different VLAN?
Any thoughts? Again, thanks for the excellent info.
