SmartThings Scenes Tile
This is a proof-of-concept for controlling SmartThings Scenes in a Custom Tile.
https://imgur.com/Pz3d1ot
:man_technologist: This is one of several sample tiles that were built as part of the Custom Tiles release and is not intended to be a fully polished tile. Please feel free to learn from it, copy from it, or play with it.
Setup
In order to use the tile, you will need to create a SmartThings ‘Personal Access Token’ with access to Scenes and use it for the ‘token’ setting in the tile. When configuring the personal access token, make sure to check the boxes next to the Scenes permissions:
You can create a Personal Access Token at:
SmartThings. Add a little smartness to your things.
