In SmartThings app I’m able to set the TV source, when I try to do the same in SharpTools rules there’s nothing in the options list, anybody else managed to change TV’s source using SharpTools rule’s
Thanks
EDIT: I Sorted It Out
Thanks
Nice! What was your solution?
That indicates that the driver doesn’t report any options for that particular command. You may still be able to determine the available options from another attribute on the device. Or by reviewing the options that show up in the SmartThings mobile app.
Then you would flip the ‘Advanced’ toggle on in the top right corner of the Device Action block and change the input type (button left of the argument) to String and manually type in the value.
Yep, that’s exactly what I did, by viewing the attributes value’s you can pinpoint the exact value needed.
