Is there a way to add a media tile that shows live streams from cameras set up in TinycamPro (or the native NVR for that matter)?
Yes, the Media Tile supports any MJPG feeds which you can pull from TinyCam or many native NVRs.
Check out the following help article on setting up Media Tiles:
For TinyCam, the following community post might be helpful: TinyCam with WyzeCam
In order to embed a camera feed from TinyCam into a SharpTools.io dashboard, youâll enable the webserver thatâs built into TinyCam and then you can access your camera feeds as an MJPG stream with the following URL format:
http://{tiny.cam.address:port}/axis-cgi/mjpg/video.cgi?camera={id}
Thx, hmm, just seem to get a black tile when I try the above. Using Hikvision cameras, if it matters. Thinking about it though, TinycamPro is simply an app I use on my phone to view my cameras. Theyâre actually hooked up to a Hikvision NVR.
Letâs see if I can figure it out with that spycamera link, the cameras are Hikvision DS-2CD2142FWD-IS. Internal Camera IP address and port is http://192.168.1.xx:65001.
No luck so far.
For the TinyCam approach, youâll need to make sure you first enable the webserver in TinyCam and that you can access it from a browser. Then modify the URL format provided above with the IP address of your phone/tablet which is running the TinyCam webserver.
Are you trying to connect directly to the camera or do you have an NVR as mentioned in your original post?
Looking through iSpyConnect, it looks like most of the URLs provided for that specific camera model are RTSP streams which wonât work directly with a web browser and thus wonât work in the SharpTools Media Tiles either.
From the iSpyConnect page, youâre looking for a âTypeâ of either MJPG or JPEG and the âProtocolâ needs to be http.
From what Iâve seen on the ipcamtalk forums, it looks like there may be an MJPG option for some of the Hikvision series, but Iâm not sure if it applies to your model or not:
First you have to set the sub stream to MJPEG while this is the only one available for MJPEG request (2xx2 IP cam series).
Then use the following syntax:
http://user:pass@ip_address/Streaming/channels/102/httppreview
As with the other solutions, I would try viewing this URL directly in your browser first to see if you can get an image to display directly in your browser. Once youâve confirmed that you can view it directly in your browser, then try adding it as a Media item in SharpTools.
One thing I would note is that Chrome and some other modern browsers have started blocking the ability to have a user:pass@ip_address format embedded in pages (like SharpTools). If your camera supports disabling the username/password on your local network or has another approach for including the credentials, then youâre good to go.
If you can disable the username/password on the camera (at least for testing), then the format from the ipcamtalk forum post would be:
http://ip_address/Streaming/channels/102/httppreview
Alternatively, you might try the other formats which seem to be available on some Hikvision models:
http://[ip]:[port]/snapshot.cgi?user=[USERNAME]&pwd=[PASSWORD]http://[ip]:[port]/cgi-bin/snapshot.cgi?chn=[CHANNEL]&u=[USERNAME]&p=[PASSWORD]http://[ip]:[port]/cgi-bin/snapshot.cgi?loginuse=[USERNAME]&loginpas=[PASSWORD]http://[ip]:[port]/api/mjpegvideo.cgi?InputNumber=1&StreamNumber=[CHANNEL]http://[ip]:[port]/cgi-bin/viewer/video.jpghttp://[ip]:[port]/axis-cgi/mjpg/video.cgihttp://[ip]:[port]/image/jpeg.cgi
Okay, canât seem to access the Hik cameras directly or via the NVR. So trying the Tinycampro route. Not sure how one âenablesâ the webserver, the only clickable option is whether to use https or not. So I clicked the Use HTTPS box. Left user name and password blank. Port is 8083.
I then inserted:
âhttp://{tiny.cam.address:port}/axis-cgi/mjpg/video.cgi?camera=1â, with my tabletâs IP address in the âtiny.cam.addressâ section and the port as 8083 per Tinycampro.
Tried with both Https and http (enabling and disabling https check box". Both timed out in my browser.
Thanks for helping btw!
ahâŚfigured it out, thereâs an enable webserver button that isnât in the âsettingsâ but in the main section of tinycamproâŚperfect!
Yup! Thatâs it. Hereâs a screenshot for anyone else who finds this thread while searching:
Edit: The HTTPS option can be left disabled as well. TinyCam generates itâs own SSL cert when that option is used which is invalid in most browsers anyway.
Curious if others are having difficulties with TinyCamProâs webserver functionality. I have tried it on a raspberry Pi and an android box, and in both cases itâs hit and miss for no reason. E.g., I can get camera 1 to feed through typically no problem. But getting other cameras sometimes returns a blank tile, and even if I access the IP address I get a timeout. Even though on the box with tinycam it works fine.
Moving to Blue Iris shortly, do I need to set up a webserver with that for Sharptools as I donât want to forward any ports for security reasons.
@S_D, have you reach out to TinyCamâs support? Many users are able to add multiple cameras with no problem, so there might be something to fix the issue.
As for Blue Iris, you do need to setup the web server in Blue Iris, but you donât need to forward the port if your tablet or whatever device running SharpTools dashboard is in the same network with the Blue Iris server, because the video will be streamed to the tablet directly without going out of your home network.
What type of Android TV box? The NVIDIA Shield TV is recommended by the TinyCam developer. Iâve seen at least a few cases of people who were having difficulty with TinyCam running on Fire tablets or other low powered devices switch to the NVIDIA Shield and have much better experiences.
As James mentioned, Blue Iris has a built-in webserver that can be enabled. If youâre just using Blue Iris on your network, you wonât need to do any port forwarding and may want to change the Authentication option to âNon-LAN Onlyâ:
