I have two Honeywell Lyric Thermostats and have several rules to control them in two separate groups.
Changing setpoints based on Home-Mode: these all work fine
Changing thermostat mode based on the status of doors and windows.
I run an automation directly in SmartThings to set the thermostat mode to off if a door or window is open for three minutes. This works fine
I have a SharpTools rule that runs when a door or window is closed. It checks to see if all doors and windows are closed, if so, it sets the thermostats to auto mode. The rule is running, but the thermostat modes aren’t updated.
Anyone having success with changing modes on these thermostats?
