We are excited to announce support for Hubitat Elevation - the home automation platform that focuses on fast, reliable, local execution using the Hubitat Elevation Hub!
Important: You must upgrade to firmware 1.1.3 or newer on your Hubitat Hub in order to take advantage of this integration.
This release includes support for Hubitat via the SharpTools.io web dashboard and Rule Engine and includes the ability to:
- View and control your devices
- React to device changes and build rule conditions on device state
- Change modes and react to mode change events
- Arm/Disarm Hubitat Safety Monitor and react to HSM events
- Build rule conditions based on mode or HSM state
NOTE: Weāve had a few reports of people having trouble with their authorizations āstickingā which may be related to parent-child devices. If you have any parent-child devices and are having trouble authorizing your devices, try authorizing just a single simple on/off switch first and then add more devices from there.
Integrate Hubitat into your SharpTools.io dashboards:
Integrate Hubitat into your SharpTools.io Rule Engine automations:
Frequently Asked Questions
Q. Can I use this alongside other home automation platforms that are integrated with SharpTools?
A: Yes! You can mix and match devices, triggers, and conditions from any supported platform. This is great for having a single holistic view of your home from your dashboard⦠as well as the ability to have devices from one platform interact with devices from another platform using the Rule Engine.
Q. Do I have to open ports on my router?
A: Nope! The integration takes advantage of the Hubitat cloud relay which securely provides access to your Hubitat Hub.
Q. Are the Tasker Plugins and Android Widgets supported?
A: No, the SharpTools.io web application is a standalone product that provides Dashboards and a Rule Engine. Note that you can use the SharpTools.io Rule Engine to integrate between various platforms and your mobile device. (more details)
Q. Does the dashboard support XYZ device in Hubitat?
A: Our goal is to support a wide variety of devices across a wide variety of platforms. The release has been tested with a variety of devices including lights, thermostats, motion sensors, and more! If you find a device that isnāt supported or isnāt working as expected, please let us know!
Q. Where can I find more information about Hubitat Elevation?
A: You can find lots of information about Hubitat Elevation on the Hubitat website and the Hubitat Community!
Q. Where can I get support for this integration?
A: Feel free to post a topic here on our community site or send a message to support@SharpTools.io and we would be happy to help!
