Is it possible to incorporate Apple Music into SharpTools? I have it on my Alexa devices if that helps/makes a difference.
@Eric_Eklund, you can use Echo Speaks to integrate your Echo devices with SmartThings/Hubitat and SharpTools. Once your Echo devices are added to SharpTools using Echo Speaks DTH, you can display the album art in the dashboard and create rule to play specific song/list using searchAppleMusic command in Rule Engine. See the thread below for the details how to create “jukebox” dashboard.
