Gauge Tiles (arc and radial)
By popular feature request, we’re releasing a few Gauge Custom Tiles!
:tada: Update: Gauges are available in Super Tiles now! If you’re looking for a simpler way to work with gauges, including customizing segments, check out the new feature!
:warning: This requires SharpTools frontend version 240510.xxxx or newer, so make sure to refresh the page on any devices that will be using these Custom Tiles to pull in the latest updates.
Gauge Tile - Gauge.js
The first option is a radial gauge using the Gauge.js library. The default design is a half arc with a pointer, but you can use the Chart Customizations setting to pass in options from their documentation.
:arrow_double_down: Import Gauge Tile - Gauge.js
This also includes some basic settings included as defaults in the Advanced Customizations setting field for quick adjustments:
  • label: hide or show the label (default: false)
    • Accepts a boolean true/false to hide or show the gauge
    • Accepts one of "top", "middle", "bottom" for custom positioning
  • min: set the minimum value
  • max: set the maximum value
  • units: override the displayed unit of measure
Starting from left-to-right, top-to-bottom we have the following customizations:
  1. Default
    { label: false, min: 0, max: 100 }
  2. Label Shown (default bottom position)
    { label: true, min: 0, max: 100 }
  3. Label Shown, Top Position
    { label: "top", min: 0, max: 100 }
  4. Label Shown, Middle Position
    { label: "middle", min: 0, max: 100 }
  5. Advanced: Static Zones
      label: true, min: 0, max: 100,
      staticZones: [
        {strokeStyle: "#F03E3E", min: 0, max: 33},
        {strokeStyle: "#FFDD00", min: 33, max: 66},
        {strokeStyle: "#30B32D", min: 66, max: 100},
  6. Advanced: Gradient Color by Position
      label: "middle", min: 0, max: 100,
      generateGradient: true,
      percentColors: [
        [0.0, "#43a047"],
        [0.50, "#f9c802"],
        [1.0, "#ff0000"]
Make sure to read the documentation from Gauge.js around the advanced customization options and make note that the formats for the static zones vs the gradient by percent are different formats. The zones are actual static value ranges whereas the percentColors are the fractional percent as a value between 0-1.
Other Common Options:
  • fractionDigits: 0
    The number of decimal digits to display
  • units: "km/h"
    Default: unit of measure from the attribute, pass a custom string to override
Gauge Tile - Apex Charts Donut
The next is a new Gauge tile using the Apex Charts library. The default design is a donut style gauge, but you can use the Chart Customizations setting to pass in customizations from their documentation.
:arrow_double_down: Import Gauge Tile - Apex Charts
The first tile is the out of the box look and feel with a basic customization to complement the base customizations we made to the Gauge.js tile above.
Apex Charts is quite a complex and robust library with tons of customization options. The second example is quite a whopper of a customization snippet copied directly from their examples in their documentation.
Advanced Customization Example (tap to expand)
  colors: ["#20E647"],
  plotOptions: {
    radialBar: {
      hollow: {
        margin: 0,
        background: "#293450"
      track: {
        dropShadow: {
          enabled: true,
          top: 2,
          left: 0,
          blur: 4,
          opacity: 0.15
  fill: {
    type: "gradient",
    gradient: {
      shade: "dark",
      type: "vertical",
      gradientToColors: ["#87D4F9"],
      stops: [0, 100]
The intention of this was to show what’s possible with this type of gauge, but if you want to use heavy customization like this across multiple gauges, I would recommend importing another copy of the custom tile and customizing those options directly in the custom tile code.
Otherwise using heavy customizations in each tile could start to slow down your dashboard loading and will increase the data size of your dashboards with all the redundant / duplicate customizations.
Nice stuff team!
Would it be possible to show a custom text attribute for the unit? Ie: kWh
Also 1x2 seem to cut the value off
I pushed out an update to the arc gauge which supports a new units option in the Chart Customizations (JSON) which allows you to override the unit of measure displayed.
{ label: true, min: 0, max: 100, units: " kWh" }
You can update from source to pull in the latest updates.
The arc gauge itself should be visible in a 1x2 tile, but yeah… there’s not enough room for the label/value with that aspect ratio.
This was a really quick turn-around for that update! Thanks Josh. I just managed to replace a portion of my home energy monitor super tile with a few graphs beneath:
Screenshot 2024-05-20 at 10.37.16
That looks great, thanks for sharing! :star_struck:
It seems like you might have already come up with a solution for this request:
…overlapping two inputs on one graph ie : solar production and solar usage on the same model
An approach I’ve seen for graphing that type of energy consumption is to graph the net ratio of contribution / consumption from the grid or solar which you can do with a bit of math in an expression. (eg. -1 to +1)
Yeh this is pulling the data from Hubitat devices into variables then a calculation is performed on the Sharptools side. FYI the charts work with negative low numbers - which is great (for net consumption)
@josh,
Is it possible to implement the following:
gauge.animationSpeed = 32; // set animation speed (32 is default value)
I have tried in the code but with no luck. I get no gauge displayed at all.
I am hoping to speed-up the animation because when using for a high number it takes a while to reach the actual value.
From a quick review of their documentation, that looks like the right syntax. And from a quick check of their code, it looks like you must programmatically set that value as it doesn’t seem to get set along with their ‘regular’ options.
I’ve gone ahead and updated the tile so it supports animationSpeed as a property in the Advanced Chart Customizations:
{ label: false, min: 0, max: 100, animationSpeed: 5 }
Wow, can’t ask for faster response than that. Thanks Josh.
The gauge is a nice addition I’m using to display temperatures. Would it be possible to add a setting to display number of decimals?
Regards,
Niclas
You can do this in the code.
Change digits on line 194 to your needs …
function formatNumber(number, digits=1) {
Thanks Nezmo, works fine!
I just pushed an update so you can specify the fractionDigits as part of the advanced configuration so you don’t have to tweak the code. :slight_smile:
{ label: true, min: 0, max: 50, fractionDigits: 1 }
Nerd Details (tap to expand)
In the original release of the Gauge Tile, I had implemented the fractionDigits setting using the native feature of the underlying Gauge.js library that we are using, but there was a bug related to how we are using the library. :blush:
The Gauge gets created before the settings are available, then we update the settings in the Gauge once they are ready. I didn’t realize that updating the Gauge settings did not update the Label formatter, so I tweaked that with this update.
Much appreciated Josh :smiley:!
Whats the code in the JSON to write the title (UV-Index) or the measures (0.31) smaller?
Screenshot 2024-06-09 192424
The “UV Index” in your screenshot is the standard “Label” setting for the instance of the tile on the dashboard.
The decimal formatting was covered just 1-2 replies up in the thread.
You can play around with the value on line 289 in the code to achieve this. For example, I have:
font-size: 15vh;
EDIT: Sorry, it’s line 300 now. I did not have the latest loaded.
Hi Josh.
Thanks for your support.
I have a problem with this code. When i copy the “static zones” code it works fine, but when i try the “Gradient Color By Position” it just show the “Default” it is like “Gradient Color By Position” code is not working all the other codes works fine. on the picture is the 1 Static Zones 2 Gradient Color by Position what am i doing wrong.
Please help…
There was a comma missing after the ‘max’ value in the original example. I’ve updated the example in the original post.
-    label: "middle", min: 0, max: 100
+    label: "middle", min: 0, max: 100,
    percentColors: [
      [0.0, "#43a047"],
      [0.50, "#f9c802"],
      [1.0, "#ff0000"]
Or here’s the full version for your reference and ease of copy-paste:
    percentColors: [
      [0.0, "#43a047"],
      [0.50, "#f9c802"],
      [1.0, "#ff0000"]
