I have some ST contact sensors as well as Cygnet ones which I run with a Sonofff driver in Hubitat.
As can be seen below, the ST ones work as expected (Open/Closed) however the Cygnet ones report a ‘Present’ state which isn’t useful at all - Is there a way to adjust this?
It looks like the green one is implemented as a presence sensor. If it’s also implemented as a contact sensor, you may be able to use the Change Layout feature to select the contact sensor layout.
Depending on what type of hardware you have, you may have different options. For example, some devices expose ‘favorites’ or ‘playlists’ which can be accessed from rules as shown in the Jukebox Dashboard post.
Alternatively, there’s a Spotify Custom Tile available in the community. It was more of a proof-of-concept, but depending on your needs it might be an option for you.
