BUG (?): Label when dimming lights is not using label override
My lamp had the original text “Spotter kjøkken”. I override the label for the tile to “Taklys”. This updates the label in the tile itself, but not in the popup where you can dim the light. The popup is stil using the original label, but I would expect that it used my new label.
Skjermbilde 2023-05-26 kl. 12.24.44
Is this a bug or a feature?
It’s by design. The device name is always used in the dimmer popup. The label is just changing the label of the tile itself.
You can update the device name in your source system, but of course that will change it everywhere.
PS. Your theme looks great! It looks really similar to a design that another user put together. Did you create the CSS from scratch or was it posted on the community somewhere?
I see! Is this a feature change that I could request, or is this a feature that you would like to keep as it is?
Yes, my design is heavily influenced/copied by the post you are refering to. I have recreated the css my self.
Absolutely! There’s a feature request category here:
