Hi, I am using Hubitat virtual dimmers as volume controls. When I change the dimmer percentage this then adjusts the volume to the same percentage in the room selected.
Everything is working great except I can’t change the name of the dimmer text on the pop-up window.
It is defaulting to the name of the Hubitat variable and not the label I used in the tile.
It would be great if the text display used the label? Thanks.
