If your tablet is having difficulty displaying your Blue Iris camera feeds, you might consider reducing the resolution of your feeds or using periodically refreshed image snapshots instead.
This is especially important on lower powered tablets like Amazon Fire Tablets which are a popular choice for displaying dashboards, but are relatively low powered. Displaying MJPEG feeds on Fire Tablets tends to put a decent amount of load on the devices, so there are two primary approaches:
URL Parameters
To display a lower resolution stream, you can use a few URL parameters:
q
= quality (1-100) -
h
= height (px),w
= width (px)
Usew
andh
together or independently. -
s
= scale (1-100)
Note: The scale (
s
) parameter may not work on some MJPG feeds, but should work well on image snapshots.
Here are a few examples:
/mjpg/{camera-short-name}?q=80&w=640
Requests a quality of 80% and a width of 640px. -
/image/{camera-short-name}?s=50
Requests an image snapshot that is scaled to 50% of its original size.
Periodic Image Refresh
As an alternative to using MJPG feeds, you might consider using an image snapshot that refreshes periodically. Viewing several MJPG feeds on a lower powered tablet can put a lot of stress on a Fire Tablet. Viewing JPEG snapshots tends to take fewer resources and puts less of a load on the devices.
You can even set the image snaphots to refresh every few seconds. For example, a common approach is to have a local security camera image refresh every 5 seconds.
As noted above, the URL format is:
Image Snapshot Tile with MJPG when Tapped
One other cool approach is to display the periodically refreshed image snapshot in your tile and then display the MJPEG feed when the tile is clicked. To do this, setup your Media Tile using the image snapshot as normal, then edit the Media Tile to display the MJPG stream when clicked:
- While editing your dashboard, tap the
on your Media Tile and select Edit - Change the Action (Tap) to Open Hyperlink
- Enter the URL for your MJPG stream in the Hyperlink field and press save
Now the Media Tile will show an image snapshot that refreshes every few seconds… and when you click on the tile it will open the MJPEG stream.
