Yes, using the SharpTools Rule Engine, you can copy data out of a device attribute and into a SharpTools variable.
We don’t currently have a way to display a Text Variable as a Media Tile, but that sounds like a great Feature Request if you want to create one!
Side note: There’s also a feature request for HTTP Triggers for SharpTools Rules that could enable you to post data directly from Homeseer into SharpTools Variables using SharpTools Rules that you may wish to cast a vote on.
Edit:
HTTP Triggers for Rules are now released!
New Feature: Rule HTTP Trigger
Since SharpTools supports the display of album art for Music Player devices, you could write the image URL directly to a device in Hubitat which implements the Music Player capability.
For the Album Art Tile, the device would need to implement the Music Player capability.
Within that capability, there’s an attribute called trackData (or audioTrackData in SmartThings) which is a string version of a JSON object which should have at least the following fields:
image: "http://your.album/artwork.png", // 'albumArtUrl' and 'trackImage' are valid alternative property names
title: "Track Title" // 'name' is a valid alternative
album: "Album Name",
artist: "Artist Name",
source: "spotify", //optional, 'mediaSource' is a valid alternative property name; icons are displayed for 'spotify', 'google play music', 'apply music', 'pandora', 'amazon music'
