Is there a way to add Alexa devices to the dashboard?
Hi @Bud_Odd_Jobs, do you mean adding Echo speakers to dashboard? If so, you can add them to SmartThings/Hubitat using the community developed DTH - Echo Speaks.
See the post below for more details about adding Echo to dashboard and even using Rule Engine to change the music played on Echo.
v:* { BEHAVIOR: url (#default#vml) }
Wow! Thanks James. That sure was a lot of steps to set up the Echo Speaks! Not for the faint at heart. Made it through without a problem. Greatly appreciate your help! You are awesome!!
Bud
I guess the echo speaks no longer works, right?
For smartthings you are correct - Samsung close Echo Speaks due to the resources required to maintain it. Tonesto originally was going to produce a Lite version, but due to time constraint and complications he decided to move on. Last I knew it was still supported on Hubitat. So far this is the only smart app that I have lost that I miss. Hopefully more do not follow suit (specifically Blue Iris Fusion).
