I have been following the instructions to get my Axis cameras on my Sharp Tools dashboard, but I am not having any luck. Any help would be appreciated. I have them streaming in TinyCam as well, but when I add the media into ST, it fails to load the stream. Probably missing pertinent information, so let me know what I can provide to get this figured out.
Hi @Jeff_Smith1 can you please describe your setup with some more details? What URL you used in the Media tile, and if you can open the video url in the browser directly to see the live stream? Are you using a username & password when accessing the video stream from TinyCan? Have you tried to remove the login requirement and test it if the issue is the credential related?
I cannot for the life of me get this to work. After watching several videos and tutorials the URL works just fine in a browser “http://192.168.50.176:8083/axis-cgi/mjpg/video.cgi?camera=1” but will not work in sharptools. I’ve tried with and without credential, HTTP and HTTPS and using jpg/image
vs mjpg with no luck.
James it appears that it was an HTTP issue. I updated Tinycam to use SSL and it appears to be working like a champ. Thanks again for the assistance and looking forward to using Sharptools!
Hi my friend, you can setup an android old no usable mobile as a TinyCam “server”, then you can add an hyperlink in your iOS dashboard … I hope this tip is useful for you, I will take this way soon…
Hi my friend, I have not set it yet, I just made a test with my daughter Android phone by 3 days, and seems work fine, some light and ocasional freezing, not to be worry about, the only issue is Tiny Cam app has to be open all the time, thats why a specific Android device has to be assigned as a server. I cannot guide you about the ridght specs but the device where I tested was a Huawei mobile Y6 2019, RAM 2 Gb. I think I will get a regular Android 2 Mb Ram… but I will use it only for 1-2 devices, maybe 6 cams could be too much ?, maybe you need to split them in 2 mini servers.
