Hi All,
I currently have many thermostats controlling the heating in my house and since i started using Sharptools it has transformed the way i think about automation!
Now the next step is attaining weather from an online source that would include the usual - weather conditions(rainy,sunny,overcast etc) + wind speed & direction + temperature.
i dont see an obvious way to add this as a trigger - can anyone help as i am new to Sharptools but so far extremely impressed with everything
Here is a rule that will set a bunch of variables that might get you what you are looking for. You would need an Open Weather Account. It is triggered every 10 minutes by a variable changing true/false.
Most of the examples in that thread are using the OneCall 3.0 API which is documented here:
As noted in the document, you would need to sign-up for an OpenWeather account and wait a few hours for your API Key to become active, then use the URL format @JKB121 showed in his screenshots within an HTTP Action in your rule:
Edit: Oh, and there’s also a neat thread about using Chat GPT along with the aforementioned weather API to get some neat AI generated summaries: Open Weather API (and Chat GPT)
