Ive just started using sharp tools and on one section of my dashbiard all temps but can the box display be changed to a circle? I found in themes how to round the edges but I would prefer circular instead of square boxes.
Thanks
Dom
Thanks
Dom
I discovered gauges which look really good but can the blue background me made transparent?
Which blue background? If you are using the native gauges available in Super Tiles, the standard dashboard theming / styling can be applied to the tiles background color (even making it transparent and disabling the shadow if you want the gauge to visually appear standalone)
If I remember correctly, the community released Gauge Custom Tiles pass the standard tile background through as well, so same concept applies there with styling the underlying tile itself to achieve the look you’re after (including transparent).
I found the gauges in super tiles and wound up changing the background in themes where I made eveeything black. Im new at this ao im continuing to experiment and use chat gpt to help. Ive been looking at everyone’s dashboard to get ideas.
A post was split to a new topic: How do I update Ecobee rules after switching units?
