I am fairly new to Sharp Tools and have no coding background, but love tinkering with my smart home at the cost of my family’s sanity when I experiment.
I currently have my house put on a show when someone approaches my front door using a rule with a trigger from a front door sensor. Is there any way to suppress repeating the trigger for about an hour until my little “show” ends?
The Amazon Alexa app has a feature like this in its “Routines” section, but I would like to see if I can utilize such a feature using Sharptools.
Any assistance would be most appreciated.
Thanks!!!
Mark
josh
February 7, 2020, 9:05pm
#2
Hey @Mark_Montemayor - welcome to the community! Glad to hear you are enjoying tinkering with your smart home along with SharpTools!
Check out the following post by @James which shows how to use a Virtual Switch to prevent how often a rule will run:
Hi @Jim_Simpson , welcome to the SharpTools community. You can do so by using a Virtual Switch and if_condition in the flow. Create a Virtual Switch and turn it on for 20 minutes when the rule is triggered, and use an if_condition to check if the VS is On to determine if the flow should change the light of the color or just ignore this rule trigger.
See the rule example below that I used the VS in the if_condition as the first activity in the flow to determine if it should continue the flow I wa…
Thank you so much for the insight, Josh.
I am having trouble understanding how I can create a Virtual Switch. It looks like I create something in my Smartthings Classic App like a true switch and use that as the determining factor for a condition.
My only problem is: how do I create a virtual switch without having to purchase another individual device?
Thanks, Josh.
Mark
josh
February 7, 2020, 10:19pm
#4
The following post from the SmartThings community explains how to create a virtual switch:
Virtual / Simulated Device Types are functional “Things” but are not physical devices you have. Installing them allows you to control them via SmartApp’s just as you would a physical smart device.
Creating Virtual Devices - On/Off Switches
There are many reasons you’d have the need for a virtual switch.
You want one switch to control multiple other switches and/or commands.
You have a multi relay device and want to control the relays individually. (currently ST doesn’t support this)
You could use virtual switches the same way you’d use Hello Home Actions, to take care of multiple actions or state changes with the change of your virtual switch state.
How To create a Virtual Switch
Login to the IDE @ https://graph.api.smartthings.com/
Click My Devices
Click the New Device Button
Enter a Name
for the device, this can be whatever you want.
Enter a Label
for the device, this is optional and can be whatever you want.
Enter a Device Network Id
This can be anything you want. I recommend short and sweet but it cannot duplicate other device ID’s. Lets say it was a virtual switch for your living room lights, maybe call it LRVD01
Zigbee Id
should be left blank
Select a Type
from the dropdown, this should be Simulated Switch
Version
should be published
Location
should be your hub location, probably “Home”
Hub
should be your hub name.
Group
you won’t be able to select when creating, but these are Groups you’ve created in the Things page in the SmartThings app.
Click Create
Now you have a Virtual On/Off Switch in Things on your SmartThings App. You can use this Virtual Device
The process is very similar for other Virtual Devices, instead of Simulated Switch you can choose from many other Simulated Device Types.
Thanks so much, Josh.
I successfully created the virtual switch and added it to my rules. Let’s see how it goes.
Thanks again!
Mark
