Simulated temp bulb's tile doesn't give temp slider
Using the “Simulated White Color Temperature Bulb” device that’s available in the ST IDE, I made a switch which is the trigger for an automation in Smart Lighting to control 6 Halo dimming+temp controllable downlights. When I look at the related switch in the ST app I have access to the on/off toggle, the color temp slider and the dimmer slider. However, in my SharpTools dashboard, when I exit the tile for that switch, I see no option to display the temp slider, just the options for the toggle and dimmer. Is there a way to see the temp slider in the dashboard for this type of device?
Thanks.
A post was merged into an existing topic: How to adjust white color
