@Denver, just to throw another option without having to use AutomateIT. You can also use Rule Engine and create a Fully Browser device using the Fully Kiosk Browser Device Handler to open the Ring app when the Ring button is pushed. I personally would suggest not to include the “AND motion is active” in the condition, but would be the rule example for what you described. (If you want the same behavior when the Ring button is pushed OR motion occurs, you can remove the IF_Condition, and add the Ring motion status changes to “active” in the Trigger section.)
EDIT: update the rule example to trigger the rule when either Ring button is pushed or motion is active, and update the command to bring Fully browser to front 1 minute after.
