As of right now, adding the rule to your dashboard to manually execute it is probably the best approach.
@James has it on his hit list to improve the testing / debugging features of setting up rules though, so I’ve tagged him here for his reference. ![]()
Update: This topic is from several years ago and many features around testing and triggering rules have been added since then including variables, HTTP Triggers, rule logs, etc.
There’s a feature request to manually trigger a rule if you want to cast a vote and reply with your use-case, but it hasn’t had any interest at the time of this edit.
