Hi, just creating some rules and I didn’t see an option to quickly test a rule? Did I miss it or the only way to test a rule is to add it to the dashboard?
Thanks all
Thanks all
As of right now, adding the rule to your dashboard to manually execute it is probably the best approach.
@James has it on his hit list to improve the testing / debugging features of setting up rules though, so I’ve tagged him here for his reference. ![]()
Update: This topic is from several years ago and many features around testing and triggering rules have been added since then including variables, HTTP Triggers, rule logs, etc.
There’s a feature request to manually trigger a rule if you want to cast a vote and reply with your use-case, but it hasn’t had any interest at the time of this edit.
OK thanks. Just making sure.
