Popp flow stop 2 is paired to Smartthings (official integration) and exposed to SharpTools. For some reason it just shows status (open/close) but can’t be controlled via Sharptools dashboard.
Sharptools shows that device has these commands available: ping, close, poll, refresh, open.
Any ideas what causes issue? Flow stop is working normally and can be controlled from Smartthings and from actiontiles dashboard.
Can you share a screenshot of what you are seeing on your dashboard?
It sounds like it’s rendering as a Valve Tile in which case the ‘Open’ and ‘Close’ commands are small links in the bottom left corner of the tile. There’s currently a Feature Request out to make the Valve Tiles tap to toggle like light switches which you can vote on here:
There are some other approaches you could take in the meantime. For example, you could create a rule in the SharpTools Rule Engine and expose it in your dashboard:
