When I manage the connections to my Hubitat hub its missing Voltage, Humidity, and Generic devices. They show up as devices on the Hubitat hub so they do exist. And when I was previously connect to a smartthings hub they were there also.
Hi @kampto, see the steps in the post below. You should be able to authorize them to SharpTools as long as the devices have Actuator or Sensor implemented in the device handler.
OK, did that. I still cant see them in Manage Connections but they there in the “Things” when I edit dashboard. Thanks.
