Update:
There’s now a Hubitat Virtual Button custom tile available to more easily integrate HE virtual button devices into your dashboards.
Which driver are you using for the virtual button?
You can find some details around Virtual Buttons in Hubitat + SharpTools, including some alternative approaches you can take, here:
There are several different approaches you can take:
- Change to a Virtual Switch and enable the ‘Auto Off’ setting
- Change to a Custom Virtual Momentary Button driver
- Use a SharpTools Rule to send the
push()command to your button or run the actions directly - Use a Super Tile - you can use commands like
push()directly as an action
