Any thoughts of supporting Hubitat?
Not to answer for Josh, but until he respondsâŚ
I asked this question a few weeks ago and his answer was, âItâs on my hit listâ. I know he has a Hubitat (one of the earlier) and has done some basic porting.
A lot of my Smartthings automations rely on presence and other integrations with my Android phones, all of which depend upon Tasker and SharpTools. So, complete conversion to Hubitat wonât be until SharpTools comes over.
As @Charles_Lacey noted, itâs on my hit list. ![]()
To be transparent as possible, Iâm still working on wrapping up some improvements to reliability of the Tasker integrations thanks to Androidâs Doze mode (see details here) and there are a few improvements I want to get rolled out with the SharpTools.io web dashboard before I look at other integrations.
My long term vision for SharpTools.io is to expand the capability to integrate with more smart home platforms and individual smart devices. Considering that porting apps from SmartThings to Hubitat is relatively straightforward, itâs logical that it would be a decent candidate for the expansion.
I would note that my initial plan for Hubitat would be a cloud based integration (although Iâd personally like a local integration at some point).
Iâm also interested !!!
The latest SharpTools.io platform release actually includes the backend code for Hubitat. We are working with the Hubitat team on official release.
Iâll need to do some work on updating the mobile app to use the new platform integrations, but we are headed in the right direction!
I donât see Hubitat listed in âManage Connectionsâ
Based on discussions with the Hubitat team, Iâm hopeful theyâll have the connection included in the next Hubitat firmware release. Then we can flip a flag to enable it on our side as the code is already released on the SharpTools.io platform.
Great news, @josh ! Assuming the Hubitat integration is going to be cloud-based, but ⌠???
I use SharpTools on ST for several things, but the critical functions are setting modes based on presence. Will those two items be implemented?
@Charles_Lacey just to clarify, the first pass of the integration is between Hubitat and the SharpTools.io platform (web) which includes the web dashboard and Rule Engine. The next step is to rework the mobile app to integrate with the SharpTools.io platform so it can leverage the new integrations as we develop them.
So when the connector is released on Hubitat, it will support SharpTools.io web dashboards and Rule Engine, but the SharpTools mobile app will not have Hubitat support until we are able to rework it.
â
That being said, since the SharpTools.io platform has cross-platform support between all of the supported connections, you can use the Rule Engine to âsyncâ Hubitat with events on SmartThings.
For example, you could use your existing integration with the the SharpTools mobile app to set a SmartThings mode based on presence⌠then using the Rule Engine you could create a rule that says:
IF SmartThings mode = 'Away'
THEN SET Hubitat mode = 'Away'
Same goes for other things like Smart Home Monitor (SHM) and Hubitat Safety Monitor (HSM):
IF SmartThings SHM = 'Armed Home'
THEN SET Hubitat HSM = 'Arm Home'
And for reacting to events from Hubitat on your Phone, in place of the âThing Stateâ SharpTools Tasker plugin, you could use a rule along with Pushbullet (which also has Tasker support).
IF 'Living Room Motion' = 'active'
THEN Send Notification:Pushbullet '#LivingRoomMotion=active'
Iâm doing something similar with Send Hub Events on ST linked to Hub Link on HE already.
I just stumbled upon Sharptools.io tonight, so forgive me for any ignorance here, but I have both Hubitat and ST running and handling different devices. Is it going to be possible to have a mix of both Hubitat and ST managed devices on the same dashboard?
Yes! In my screenshot a few posts up, the lock and thermostats are on SmartThings and the rest is on Hubitat. So you can definitely mix and match devices from different platforms on a single dashboard. ![]()
Same thing goes for the SharpTools.io Rule Engine - you can mix and match between supported platforms in one or more rules.
Thanks! Iâm looking forward to monitoring this when you have Hubitat functionality available for all. Thanks!
The Hubitat integration for SharpTools.io is now available as part of Hubitat Hub firmware 1.1.3. You can find more details on the integration in the following thread:
Hi,
Thanks for supporting Hubitat! Just tried to link the app but didnât get very far.
- I installed the app on Hubitat and selected a few devices.
- Went over to SharpTools and created an account
- Click on "Manage Connectionsâ
- Select âHubitatâ
- Select my hub âHomeâ
- WaitâŚwaitâŚwaitâŚ
- Get âoopsâŚInvalid Requestâ with a âTry againâ button
Iâve tried deleting the app from Hubitat and reloading it. Keep getting the same thing. Donât see anyway to delete my SharpTools account, so I could reset that.
Any ideas?
Hm. Invalid Request is usually reported directly from the remote OAuth servers. For example, I saw that in testing if I wasnât on the latest Hubitat firmware release which has the SharpTools App available.
What are you seeing in your Hubitat logs when you try to authorize things via Manage Connections from SharpTools?
Edit: handling via PM on the Hubitat community. ![]()
Update⌠@josh got me up and running again. Seems somehow my Hubitat wasnât taking to the cloud. A second reboot after the update has fixed it. ![]()
Hubitat no longer connected. Rebooted twice and re-auth and still wont stay connected. Logs in HE show subscribing and sending data but sharptools wont connect anymore.
2018-08-16 17:41:48.635:debugEvent data successfully posted to SharpTools.io
Can you clarify what you mean by âwonât stay connectedâ and âSharpTools wonât connect anymoreâ?
The log message indicates that your Hub has a valid SharpTools.io API token and is able to successfully send data to the SharpTools.io platform.
