Michael-
Thanks for posting and sorry to hear that things arenât working as expected. Are the dashboards actually showing completely empty or all of the Thing tiles are showing Placeholders? A screenshot might be helpful.
The first step I would take is to reboot the Hubitat hub, wait several minutes for things to calm back down, then we authorize things starting from your SharpTools.io user page.
As a troubleshooting step, I would try authorizing only the devices you are actively using on dashboards. First that doesnât help, try deauthorizing everything, then authorize just a small batch of devices. Itâs possible you have a device or devices which are causing the hub to bog down or the Hubitat cloud relay to fail during the device synchronization process.
I canât connect SharpTools to either of my Hubitat Hubs this morning. Both hubs are working - SharpTools just says ,âOops - something went wrongâ
That message comes directly from Hubitatâs Authorization service and indicates that they cannot communicate with your hub.
I just tried on a few hubs as well and It is not working for me either. It seems that the Authorization Services (or part of the cloud relay?) is having some sort of outage.
I am using the Hubitat App using mobile data and wifi off - and I am able to access the HE Hubs through the Dashboards but reports that 'Safari cannot open the page because your iPhone is not connected to the internet."
Interesting because Safari is work just great using my 4G connection - interesting that Hubitat is reporting the iPhone is having issues.
Anything that uses the Hubitat authorization services / cloud relay is going to be impacted. I just tried reauthorizing Google Assistant, Alexa, and IFTTT and they are all experiencing the same issues.
Hello, from one moment to another I lost the connection between my Hubitat c7 and sharptools (Running on a tablet). I rebooted the HE and it still doesnât work. I get the following message: "Oops!
Hub is not responding, please verify it is running and connected to the Internet. "What I have not tried yet is to restart my Router.
Hi @Ignacio_Fotografias - welcome to the community and thanks for posting. Iâve merged your post in with an existing thread about the same topic.
Hubitatâs Authorization services seem to be experiencing some sort of outage at the moment as services like SharpTools, Google Assistant, Alexa, IFTTT, etc are unable to authorize devices from Hubitat at the moment.
No. In your case, a device sync likely ran during the Hubitat outage⌠when SharpTools asked Hubitat for the list of devices you currently had authorized, it responded with no devices.
All of my Hubitat devices are still connected and I can still control them, but I cannot authorize any new devices.
Ok thanks - so the Dashboards that are showing with ALL devices removed will be restored when ST is able to re-connect to HE.
Because I will need to identify from the Dashboards all the devices each Dashboard uses so I can add it back into the Sharptools sync in HE that I was asked to remove earlier.
That is a massive relief to not have to recreate all those dashboards again.
Yes. Avoid editing the dashboards or removing tiles from dashboards.
The âPlaceholderâ tiles are placeholders for devices that are no longer authorized to SharpTools. Usually this occurs when you explicitly deauthorize a device⌠when you reauthorize the device, it rehydrates that device in whatever dashboards or rules it was used in.
In this case, it looks like the timing of a device sync for you lined up with whateverâs going on with the Authorization systems / Hubitat Cloud Relay at the moment.
As long as the placeholders are there (eg. donât edit the dashboards), they will get rehydrated when you are able to get them synced over again.
Just an update that Iâve edited the topic title (and some of my replies) to clarify that this doesnât seem to be a complete outage of the Hubitat Cloud Relay (which is used to communicate with and send commands to your hub), but seems to be primarily impacting Hubitat Authorization services.
If you already had devices authorized and they are displayed on your dashboard, it seems that you can still control them.
It looks like your case is a bit unique in that something happened to lose the devices (eg. device sync / auth issue) and since the Hubitat authorization services are down you canât reauthorize them to bring them back.
I have no placeholder tiles just blanks were all the Hubitat devices were.
Had to enter edit mode to capture the screenshots requested.
As long as you have them backed up not an issue, just a matter of accessing the backups and working out what devices need to be shared on the HE in the Sharptools app.
I would have to take a closer look to see whatâs going on - I can take a closer look at Placeholder tiles when Iâm back in the office next week. It looks like youâve got a customized Theme, so Iâm wondering if the âPlaceholderâ text is staying âblackâ and since the background is black itâs just not visible.
The dashboards still have a reference to the Thing⌠itâs just that SharpTools doesnât have access to the thing anymore so itâs not displayed. Itâs not a âbackupâ so much as the reference to the Thing just needs to get restored.
As mentioned above, avoid editing your dashboards. Once the Hubitat Authorization services come back online, reauthorizing the devices should get them rehydrated.
@Michael_Horton, @Stan_Silverman, and @Ignacio_Fotografias have you reported the issue with being able to authorize devices to Hubitat support? Just want to make sure theyâve gotten reports of this as well so they are aware of the issue.
