How to set thresholds for Active Style
How can I set the threshold for a Hero Tile to change to Active on Battery?
ie Tile turns RED when battery becomes 30% or less?
Assumes Hero Active color attribute assigned to Battery
The Battery Tile layout supports this natively.
:link: Fan Tiles, Battery Tiles, Label Tiles, and More!
To use the Battery Tile layout, tap the ... in the top-right corner of your tile (while editing your dashboard), then choose Change Layout and then choose the Battery Tile option.
Then you can tap the ... in the top-right corner of the tile and choose Edit where you’ll see the settings for customizing the thresholds.
There’s also a feature request open for being able to set custom thresholds for mapping tile styles in the Hero Attribute tile which you can vote on here:
:link: Style/Icon State Mapping for Custom Attributes
Damn it that is GREAT!!!
I can heat map the house using this!!!
Awesome.
The more I use the more I like it.
Thanks - took me a while to notice the response - sorry for delay!
Actually is there anyway to change ALL Temp tiles to use a standard model
I have over 30 temp sensors in the house !!
Thanks
Not at the moment, but there is a feature request open for creating ā€˜templates’ for color states so they could be reused across different tiles if you want to cast a vote on it:
Just an update the Templates for Temperature Tile Colors (and other state mapped styles/icons) is now available in beta. More details in the associated feature request thread:
