Emerson-
That looks like the logs directly from the custom device driver. What about the steps above?
- Complete the reauthorization making sure your CO2 device is selected and synced over.
- Since it likely doesn’t implement one of the core capabilities, you’ll need to use the process noted in: How To Authorize Unrecognized Things - #4 by josh
- After completing the authorization, wait several minutes to make sure the device synchronization is complete and double check the device details in SharpTools.
- If you are adding new devices, you can watch the location details screen and the devices will sync over in real time. From your user page, tap the
...next to your location and you’ll see a list of things for that location. Once the device is synced over, you can click on the device name to view the details of it and make sure it is reporting the correct attribute name and value.
- After the synchronization is complete, manually refresh your dashboard page to kick off the healthchecks.
