We’re excited to announce the next SharpTools.io release which brings with it faster rule execution!
This change will be particularly noticeable if you have multiple rules which share a similar Trigger. For example, if you had multiple rules triggered on a particular device attribute changing. Previously, rules with a similar trigger would execute sequentially which meant that rules which shared a similar trigger could impact the performance of each other. Rules are now better parallelized and run simultaneously which results in faster rule execution!
