We are excited to announce another awesome SharpTools.io release - this one brings with it dashboard background images, transparent tiles, and a number of other great features!
Dashboard Backgrounds
You’ll now find a Background Image option in your Dashboard settings which allows you to pick from the following background sources:
- Editor Picks - a curated selection of backgrounds that change periodically
- Media - select one of your Media items to use as a background
- Bing - choose from Bing’s image of the day (or rotate between the images from the past week)
Transparent Tiles
What good are background images if you can’t see them? This release also brings with it the option to use transparent and semi-transparent tiles.
Other Enhancements
- Touch indication on tiles
- Tiles now show a waves-effect when they are touched and a small spinning indicator while actions are in progress
- This provides immediate feedback that a touch was registered and that an action is in progress.
- Improved device control speed
- Added a background process to keep your device control tokens fresh which should mean more consistent fast device control.
- Previously, if you hadn’t used your dashboard in a while, it may have taken an extra second or two for the initial device control to occur - the background refresh should improve the consistency of fast device control.
- Dimensions of Music Player tiles can now be adjusted
- This allows for 1x1 music player tiles as well as any other scale of music player tile
- Smart Hyperlink Routing
- If a Media Tile or Hyperlink links to a SharpTools.io app page (open in same window), the system will attempt to route to it directly - this means much faster page navigation, no page reloads, and a more streamlined experience.
- This is particularly helpful if you want to use Media Tiles as navigational elements. You can use whatever images you want in the Media Tile and then set the Media Tile action to Hyperlink to your desired dashboard.
- postMessage API for iframe wrappers
- Added a new
postMessage
HTML5 API for those of you that have been building custom iframe wrappers for your SharpTools.io dashboards. - View the iframe postMessage API Documentation
- Added a new
- Added support for tile color to media tiles (eg. for transparent images)
- Thermostat Tiles now have a ‘Transparent Heat/Cool Color’ option
- This option will only show if the ‘Show Heat/Cool Color’ option is enabled on a thermostat tile
- Tile Editor will reposition itself vertically to show on your screen
- Especially on mobile devices, if you had scrolled down the page and then attempted to edit a tile, the Tile Editor would remain in its original position much higher up on the screen.
- The Tile Editor will now reposition itself vertically when you edit a tile so it’s displayed within your scrolled viewport
- Other minor bug fixes (progress bar position, repeating healthchecks)
