I installed 3 sets of ThirdReality blinds. They are 3 different devices in Hubitat. They all function as they should. I have rules set up in Hubitat that opens them at sunrise and close at sunset. They operate as they should. How can I add the toggle up/down in Sharptools. They are not showing in my Hubitat devices to add in Sharptools. I’ve tried a virtual switch without success.
If they don’t have one of the primary supported capabilities, you might be able to authorize them manually as noted here:
That you Josh. That was the perfect explanation and it worked like a charm. Problem solved.
