I’m a Hubitat user for the past 3 years and I use Darksky net for my weather app and it works.
When I pull it into Sharptools all I see is what’s in the image and I’m not sure what the N/A would be, i’m assuming the weather icon?
After reading through some posts here and YouTubing, I went to smartthings and set up the weather app, and linked it, but it’s not showing any data.
I had this post typed up with the image in each section but because this is my 1st post it’s only allowing 1 image. so I put all the images in this pic below
@I_ecus_Wilson, yes the N/A is where the icon should be. Can you please take a screenshot of the device’s attribute values at Hubitat hub admin page -> devices and click on this weather device? Would be interested to see what icon it is reporting in the device.
Meanwhile, @josh had previously simplified the Dark Sky’s driver that you may want to give it a try.
If you’re using Matthew’s Dark Sky driver, make sure to enable the switch for SharpTools in the preference as that makes sure the required attributes are reported.
I have the same issue. Exactly which Driver are you using, I see a few from Mathew Scott. And will it work with WU or Davis Weatherlink? I have API keys.
And @JiiPee is using Hubitat’s built-in “OpenWeatherMap” driver. I’ve updated the Weather Tile to support the icon format from this built-in driver and should have the update in beta shortly.
What driver / device handler are you currently using?
Support for the icon format from the built-in Hubitat OpenWeatherMap driver is now available in beta. If you’re not already part of the beta, feel free to PM @support to request access.
Edit: Support for the icon format for the built-in Hubitat OpeanWeatherMap driver is now released in production.
