Is it possible to have a Zone Motion Tile, but have it indicate WHICH sensor in the zone is indicating? For my use case, I have a Zone set up in my garage that consists of 4 sensors, one in 3 of 4 corners, and one over the door. I would like to use 1 tole for the zone, but see WHIch of the 4 sensors (numbered 1-4) is active. Would this somehow be attainable?
You could use a rule for that. Have it trigger when any of the motion sensors go active, then write the name of the motion sensor to a variable… then display the variable on your dashboard (either directly or via a Super Tile for more customization control).
