I have connected my wyze cameras to Home Assistant via wyze-brdige and generic camera add-ons. I can see the life feed from the http link that HA gives me. An example of that is (http://HA_IP:8888/shed/). It also give me a rtsp and rtmp link to use as well. When i add these as media to a dashboard, i get a broken link, while the jpg works.
Does sharptools not support the http link? If not is there a way to work with this other than tinycam?
For the screenshot, the first is the http link. I looked at the link thats recommend there, but did not come up with a solution there.
HLS feeds won’t work directly with the Media Tile, but in theory you could create a Custom Tile that could view HLS feeds. If your streaming software provides sample HTML/embed code, you might be able to put that directly in the Custom Tile editor to try it out.
Otherwise if your software also offers the option for an MJPEG feed, you should be able to use that directly in a Media Tile.
