Hi… I wrote earlier, that I had wyze cam integrated, via Tinycam Pro, and I do… Looks good on PC, but it will not show up on the Tablet… Am I missing something… I am using Windows Pc 11, and Huawei Android Tablet and , Tinycam pro on a Xiaomi MI box.
It should not have to do whit Homey Pro
all my other things from HP runs fine ![]()
I am stiil missing Homey Presence
Regards Jim Denmark
Hi Jim-
I hope you don’t mind that I moved your post out of the Homey Beta thread and into the general category so other people might be able to help out.
I suspect this is related to the mixed content issue and perhaps the recent Chromium 111 changes. You can find details including workarounds here:
Note that @Gisle_Johnsen from the Homey Community also recently ran into this and the nip.io format mentioned in the linked thread resolved the issue for him.
Yes. Make sure you have allowed unsecure content in browser on device
Then url should look something like this with the nip.io:
http://192.168.1.232.nip.io/snap.jpeg
This worked for me ![]()
THX @Gisle_Johnsen
I will try that, when I get home from Work tonight
Of course, my bad, I will try the solution tonight ![]()
Hi Gisle… I can not figure it out
I use Tinycam Pro
I have : http://192.172.x.xx:7xxx/axis-cgi/mjpg/video.cgi?camera=2
Where should I put nip.io ![]()
Regards Jim
You can append .nip.io between the ip address and port + path.
http://192.172.x.xx.nip.io:7xxx/axis-cgi/mjpg/video.cgi?camera=2
Sorry for late answer. I have done what Chris_C descibes ![]()
