I have a weird situation: the stream works well (for Wyze cams) into Amazon Fire Tab HD 8, but it doesn’t work into Saphari browser. I should change something to make it work in Saphari?
Can you share a bit more detail on how you have things setup? Do you have the Wyze cams running through something like TinyCam?
hey @Vio_hal, could it be because of the self-signed certificate that you are using? If you are using TinyCam and have selected the self-signed certificate in the TinyCam web server settings, you need to make sure Safari allows that certificate.
Hi!
Today, without doing something it stated to work on Safari. Yes, I use TinyCam webserver.
Thank you!
