Hi, is anyone using any data from there withings timeline on sharptools ?
I would like to add my weight graph to one of my dashboards, but I’m unsure on how to do it.
Tony
Tony
Hi @Tony_Hobbs, you may be interested to check out the following post using Google Sheet and
Media tile to display the line chart data in the dashboard.
Or if you are familiar with the web development, you can also use the Custom Tile and Hubitat Maker API to display the history values in the chart. See below for a Custom Tile Line chart example using Google Chart API.
https://community.sharptools.io/t/line-chart-tile-covid-19-data/6598/2
And here is the example how to use Hubitat Maker API.
