I shared some tips on how to do this
Thankâs @Chris_C . That works!
Is there a way to add custom css to specific tile? I have few switches in my dashboard and if I add css it will affect to every switch tile and I would only need customize one tile.
The last example from the wiki shows how you can use a custom style named âwarningâ and the css to target it.
So its .--theme-style- and then your style name in lowercase.
Alright I have to try that one out.
I still have one question as you are now willing to answer all my stupid questions ![]()
Is there a way to change color when mode changes to night or away and same thing for HSM when mode changes to Armed?
I used to have three tiles âŚeach for location mode (Day, Away, Night). Now that Iâm using mode changer tile (just on tile) it is always as grey as it is. I would like to get more attention with colors when for example HSM is armed (so that my kids do not open door accidentally when HSM is armed)
Hi All,
Iâ have the dashboard in an iframe with some dynamic images behind it. I would therefor like to make the dashboard background transparent.
I almost got it working but on the tag i have this class: âgrey darken-3 white-textâ. Is there a way to overwrite or remove the grey and darken-3 class ? If so then it would be transparent.
/Rasmus
Make sure to use !important to override it. Something along these linesâŚ
body.grey.darken-3 { background-color: transparent!important; }
Hi Chris,
Thanks. Actually it turned out that it wasnât the !important, but the way I had written it.
Apparently it has been to long since I fiddled width CSS last ![]()
/Rasmus
I am wondering if there is a way to set the color of the thermostat control arrows. What I would like to do is change the both arrows in red circle to red and both arrows in blue circle to blue to correspond with heating and cooling. I havenât found a way to accomplish what I am trying to do.
Maybe something like:
.thermostat .heating-controls > a {
color: red;
.thermostat .cooling-controls > a {
color: blue;
And as alwaysâŚ
Please note that any custom CSS snippets provided are not officially supported and may need to be adjusted with potential future changes to the SharpTools web app.
âŚespecially in this case since itâs a fairly narrowly targeted CSS selector that we might tweak in the future. ![]()
Thanks so much. That worked after I added !important
Does anybody know css code which will let me add my own jacks icons or do I have to use ones that are already installed
@josh Is it possible to implement this box-shadow rendering order change into the STs custom CSS feature? Iâm pretty new to CSS and just looking to be pointed in the right direction.
https://blog.dudak.me/2014/css-shadows-under-adjacent-elements/
Yes, you should be able to do this with the custom CSS, but I am curious what design are you trying to achieve?
Iâm trying to add some visual depth to tiles that are clickable. Tiles that are informational only will remain visually flat. In the interest of getting the most of the real estate, I want to keep the tile spacing pretty tight. When I get the box-shadow parameters where I like, the shadow bleeds overtop of adjacent tiles making some appear stacked.
If thereâs a better way to achieve this, Iâm always open to suggestions.
it turns out much more tricky than I thought.
Since the tile div is wrapped within a couple more divs, you cannot use the linked box-shadow trick. So you may either have to adjust the shadow size to avoid the overlap, or use something else like different color/border and etc.
@James Thanks for confirming. I came to the same conclusion.
Can CCS be used to replace icons with custom hosted versions?
Can CSS pull the attribute and change background color based on value? Like for a temperature tile change color based on a temperature. I know I can build a style states to do this but adding a blanket CSS would cover all tiles in a certain theme/style.
Hi friends, Does anyone can help me to CSS configure my text variables tiles? I just cannot get adjust them. In mobiles tile has something weird effect, that makes its icon scrolls top-down when tap-swipe on them. I had made that variable value was not displayed, but an icon and specific color for variable value:
.tile.âtheme-style-iluminacionon .value {display: none;}
But:
.tile.âtheme-style-iluminacionon .icon svg {font-size: 3em } does NOT work at all.
Does anybody knows why variable tile icon could has the scroll effect ?
THANKS IN ADVANCE !
@josh would this work for hiding the icon for a hyperlink tile? Obviously it wouldnât be .tile.switch
I ask because Iâm wanting to make a hyperlink tile look like a label tile.
