I am looking to see if I can change a few SharpTools rules from getting weather updates via API to using Webhooks. I use the WeatherFlow service which has Webhook support. I can get a connection to establish and get messages back using a tester tool but I can’t figure out how to send the response data to SharpTools to trigger a rule. I get the creating of a SharpTools rule with a trigger URL - just not sure what I need to do to get a Webhook response to point to that. Do I need an actual external app to handle that?
Hi @Nezmo - I hope you don’t mind that I’ve moved this post into it’s own topic with a more relevant title.
Are you saying that your WeatherFlow service can call an external webhook and post data over to that webhook endpoint? Do you have a link to the relevant documentation? I couldn’t find anything about WeatherFlow Tempest Webhooks from a quick search… just Websockets which are completely different.
If it supports calling a webhook, you would create a SharpTools rule with an HTTP Trigger, then copy the URL that gets generated in the rule’s HTTP Trigger to use as your webhook endpoint in your source system.
I’m also quoting some of the relevant details from the other thread with a summary of the distinction between HTTP Triggers and HTTP Actions as the concept of a ‘webhook’ is contextual and depends on the source and destination.
It seems like someone else in the community wrote a listener that forwards events as HTTP requestsd to a SharpTools Rule HTTP Trigger:
Perhaps they would be willing to share what they put together?
Edit: I would also note that in theory you could create a small always-on service that connects to the WeatherFlow websocket endpoint and listens for events and forwards them. Of course, that would require the requisite developer skills.
Someone else was using IFTTT as a middleman to get the data from WeatherFlow and then forward it on as an HTTP Request (they were doing it with WebCoRE, but some concepts apply):
