I know that you suggest using the Bing map, but I must admit that due to its parameters, i.e. I can only point to a point on the map and the zoom option does not work, I cannot scale it to see the traffic volume on the road I am interested in. Have you perhaps looked at waze maps which present information in a very clear way and are accurate? There are several links provided on the waze map page to post on their map sharing pages, but none of them work in sharptools → media…
You can use the Custom Tile feature of SharpTools dashboards to embed Waze Live Traffic Maps.
It looks like you can’t just copy/paste the Waze Live Map URL directly, but while you’re on the Waze Live map in your browser you can tap the ≡ and select <> Share and Embed and then copy the URL from the Embed a Map tab and use it in a Custom Tile.
Here’s a short video showing the process:
Note that after you’ve given your Custom Tile a name and saved it, you can add it to your dashboard from the Other → Custom Tile section of the Add Item screen.
