I want to list which home windows are open in a tile on my dashboard. I already have a webcore piston that will list the open window(s) using a variable but I can’t figure out how to get the variable name in a tile instead get this random ID for the variable using a Post request with JSON. So far this is what my piston from webcore, rule and dashboard looks like (I couldn’t do an anonymized version).
Is it possible to have a tile which lists the variable name (window name) that updates as windows are opened and closed?
Might be a good question for the webcore community as the data that gets posted across would need to be a string containing the device names based on what it sounds like you’re trying to do.
I was able to create a workaround in webcore by making another string variable with my open device list variable equal my string variable, then matched the string variable in sharptools context variable.
To force the tile to be blank when all the doors and windows are closed, I created another sharptools variable with no value.
Now, if I can have the tile change color when text is inside I’d be a happy camper.
