I’m experimenting with an idea I had but am stuck. My goal was to take local weather information and I created a simple web page that pulls the information periodically. I created the page using a lot of ai help but is running great. It also had me create a simple .json page to pull just the data to sharptools. Here is what I have:
And the simple data I’m trying to pull:
https://lincolnweather-ceb455469eb3.herokuapp.com/data
I made variables for each data set so I could make a super tile for each individual. I then made a virtual switch in Hubitat that runs every 15 minutes to be a trigger.
Finally started making a rule that would use the Hubitat trigger. First action was to GET from the .json data page. Then added a new variable action for each data point (temp, wind, humidity, etc.) to pull from. This is my problem, nothing is pulling correct.
Am I going about this all wrong?
Sorry if this makes no sense, I thought it would be easy once I had the page made, but I’m stuck now.
