I’m using the Tasmota Edge Drive for some WLED presets. I’ve got some presets set, and I can’t figure out how to run them in SharpTools. There is a setPreset() method available, but I’m not able to figure out what vale to pass it.
Figured it out, embarrassingly, all you have to do is put the name of the preset as the value.
Thanks for sharing the solution! Hopefully it will help someone else looking to use the presets on their Tasmota WLEDs! ![]()
Sorry this is a little dated, but I was wondering if you were able to bring in all your presets and controls to Sharptools dashboard?
