For those of you who are into Crypto/Forex/Stocks, It’s really easy to place a custom tile with a list of your prefered tickers using a single tile with a menu inside to cycle between them, you can configure your options in tradingview (Symbol Overview) and then place it inside the HTML custom tile ( remember to place the code from TD inside a DIV container ):
For better looks, configure in TD the background as transparent and them edit the style background in the tile itself.
If you wish to take a look, here is the code from the above example:
<!-- Do not edit below -->
<script type="application/json" id="tile-settings">
"schema": "0.1.0",
"settings": [],
"name": "Crypto",
"dimensions": {"height": 3, "width": 3},
"label": {"display": false}
</script>
<!-- Do not edit above -->
<div class="TD_DIV">
<!-- TradingView Widget BEGIN -->
<div class="tradingview-widget-container">
<div class="tradingview-widget-container__widget"></div>
<script type="text/javascript" src="https://s3.tradingview.com/external-embedding/embed-widget-symbol-overview.js" async="">
"symbols": [
"BINANCE:BTCUSDT|1D"
"BINANCE:BTCEUR|1D"
"BINANCE:ETHUSDT|1D"
"CAPITALCOM:DXY|1D"
"BINANCE:EURBUSD|1D"
"chartOnly": false,
"width": "1000",
"height": "500",
"locale": "en",
"colorTheme": "dark",
"autosize": false,
"showVolume": false,
"showMA": true,
"hideDateRanges": false,
"hideMarketStatus": false,
"hideSymbolLogo": false,
"scalePosition": "no",
"scaleMode": "Normal",
"fontFamily": "-apple-system, BlinkMacSystemFont, Trebuchet MS, Roboto, Ubuntu, sans-serif",
"fontSize": "18",
"noTimeScale": false,
"valuesTracking": "1",
"changeMode": "price-and-percent",
"chartType": "bars",
"maLineColor": "rgba(209, 212, 220, 1)",
"maLineWidth": 1,
"maLength": 50,
"fontColor": "rgba(255, 255, 255, 1)",
"backgroundColor": "rgba(19, 23, 34, 0)",
"lineType": 0,
"upColor": "#22ab94",
"downColor": "#f7525f"
</script>
</div>
<!-- TradingView Widget END -->
</div>
