@josh, I have several Leviton outlets. I get the $context.event.deviceName and store it to a variable named $CottageOutlet, and its status $context.event.value goes into a variable called $CottageOutletStatus. I have a rule that triggers if an outlet goes offline. Does each time the rule executes have its own instance of the variables? This post would seem to indicate otherwise.
The reason I ask is I was wondering whether a variable would get overwritten by a second triggering of the rule within 100’s of milliseconds of the first triggering?
