I just set up a notice to text me when the fridge door is opened but that is not exactly what I want. I wasn’t sure what to look for in the knowledge base and didn’t see the option when I set it up.
What I want is for there to be a time delay when the door is opened of a min. or so. I don’t want to get a text every time it is opened but when it is left open. How do I add the delay or where is it in the knowledge base?
Thanks
From there, you can just add whatever actions you like in the rule’s Flow. For example, here’s a full rule I have setup for when my wife’s garage door stays open for 30 minutes…
@James perhaps we can add a brief article specifically around ‘state stays’ triggers (and how they relate to conditions) to the KB so it’s easier to search for?
My apologies for not being more clear. That was just an example of a rule I already had setup which watches my wife’s garage door (which has a door attribute).
For normal contact / multipurpose sensors, you can use the contact attribute for determining the open/closed status.
