The bottom right row of this dashboard is misaligned and I’m not sure how to fix. I have a custom tile 50px with a 5px gutter. Misaligned on all devices.
I thought it was the dashboard so I started over and created a new one, but I’m running into the same issue.
I don’t know what the 9-dot icons between the two rows on the left side are, but I have a hunch that if you added a couple on the right side you would regain alignment.
Thanks for posting and sorry to hear that things aren’t working as expected.
What make/model device are you viewing this on and with what browser (incl. version number)?
Edited to add that I tried to reproduce based on the information available so far, but I wasn’t able to do so. I tried to roughly reproduce the layout based on the screenshot and the information about using a 50px base tile size and 5px gutter size.
My suspicion is that there’s either something unique about the Theme / Styles, dashboard layout, device, browser, or some combination of the above that’s causing the oddity.
I believe you are correct, it has to do with the theme on the dashboard icons under the main icons. Those have a theme of transparent header, footer and tile with an 8 px border
All other styles has the default border. When I swap the dashboard icon and a spacer icon, they don’t align evenly.
